| | Joined: Jan 2004 Posts: 666 Member/500+posts | | Member/500+posts Joined: Jan 2004 Posts: 666 | Greetings, I have been following the discussion relating to the purchase of the airmap 500 closely, and yes, Avionics West does have the unit for $299. I currently have the airmap 100 but due to the fact that it is very difficult to get the proper lighting on the unit, in the cockpit, it is very hard to read in many day light conditions. Most of the time I have the unit in my hand to find a position that will illuminate the screen sufficantly to read the screen. That of course makes the yoke mount useless except as a place to put the unit when not in use. My question, has anybody been able to make a comparision as to whether the Lowrance 500 has made an improvement with this readability problem. If they have, I will be replacing my 100 with the 500. Wil Stoughton, WI | | | | | Joined: Sep 2004 Posts: 448 Likes: 1 Member/250+posts | | Member/250+posts Joined: Sep 2004 Posts: 448 Likes: 1 | Mr. Wil Venske:
Will, I don't know anything about the 100; however, the 500 works perfect in our plane. I made a night flight on Monday with the back light in the lowest position. Normally, during day flight, I'll shut the back light feature off. I don't know if you've seen how I mounted my 500 on the left column, but this sure is a handy place for it.... for a guy with bi-focals like me, I can see it very well.
Hope the information helps. Herb Rose, N5793E; KZER | | | | | Joined: Mar 2004 Posts: 16,298 Likes: 1221 Member/15,000 posts | | Member/15,000 posts Joined: Mar 2004 Posts: 16,298 Likes: 1221 | I have an Airmap 500 but have not had it that long. I have used it on only a couple of flights and think the display is easier to see than the 100 I had before. Shade and darkness should be no problem with the back light on. In direct sunlight the only problem is the light shining off the face of the unit. The display is still very readable. The font size is larger than my old 100 and the updates cost about $35 I think, maybe cheaper if you get a yearly subscription. Some of the functions take a little geting use to but I think that would happen changing from one model to another anyway. I kept my Airmap 100 just incase but so far I like my 500.
Ron Stewart N5282B KSFZ | | | | | Joined: Aug 2004 Posts: 643 Member/500+posts | | Member/500+posts Joined: Aug 2004 Posts: 643 | I just ordered the Lowrance 500. I finally said the heck with it and bought it for $299, it sounds like a great deal so I got it. I guess I'll use my Airmap 100 for a backup. I'll let you know how it compares with the 100 when I get it.
P.S. Thanks Greg for sending me your disk for the 100. I will send it back probably Monday.
Mike H BAX MI 72 150L N5454Q
| | | | | Joined: Dec 2003 Posts: 7,197 Likes: 2 Member/5000+posts! | | Member/5000+posts! Joined: Dec 2003 Posts: 7,197 Likes: 2 | Wil, I had a 100. Same problem with lighting. The unit was nearly useless to me because of it. I sold it after a few months and bought the 500. If you plug the 500 into aircraft power so you can keep the backlighting on all the time you will NEVER have a readability problem under ANY conditions. The new backlight technology is perfect. The 500 is a little less user friendly (extra steps required for some of the basic functions...very dumb!) but you get used to it. The backlighting more than makes up for the inconveneince. Buy it, you'll like it <img src="/ubbthreads/images/graemlins/cool.gif" alt="" />
| | | | | Joined: Jan 2004 Posts: 666 Member/500+posts | | Member/500+posts Joined: Jan 2004 Posts: 666 | Wil, I had a 100. Same problem with lighting. The unit was nearly useless to me because of it. I sold it after a few months and bought the 500. If you plug the 500 into aircraft power so you can keep the backlighting on all the time you will NEVER have a readability problem under ANY conditions. The new backlight technology is perfect. The 500 is a little less user friendly (extra steps required for some of the basic functions...very dumb!) but you get used to it. The backlighting more than makes up for the inconveneince. Buy it, you'll like it Hi Dan, Thanks for the taking the time to write a short but to the point evaluation and for taking the time to write it. It's exactly the type of information that I am looking for. I will be ordering my 500 today. Wil Stoughton, WI | | | | | Joined: Jan 2004 Posts: 18,962 Likes: 4 Member/15,000 posts | | Member/15,000 posts Joined: Jan 2004 Posts: 18,962 Likes: 4 | All of the advantages to owning a 500 are true, I'm sure!
The disadvantages to not owning any GPS are also true!
The disadvantages of being financially disadvantaged are a bigger truth!
I may be a few years behind the norm, but to me, my 100 is a BIG advantage over what I had (nothing)! I was taught to navigate the airways using morse code. GPS of any flavor is a vast improvement! But, I also believe in buying the best you can afford, as long as it suits your needs. Go for it! | | | | | Joined: Aug 2004 Posts: 643 Member/500+posts | | Member/500+posts Joined: Aug 2004 Posts: 643 | Wil, I had a 100. Same problem with lighting. The unit was nearly useless to me because of it. I sold it after a few months and bought the 500. If you plug the 500 into aircraft power so you can keep the backlighting on all the time you will NEVER have a readability problem under ANY conditions. The new backlight technology is perfect. The 500 is a little less user friendly (extra steps required for some of the basic functions...very dumb!) but you get used to it. The backlighting more than makes up for the inconveneince. Buy it, you'll like it I just received my Airmap 500 yesterday and was playing with it last night. I find what Dan said to be true. One thing I really like is how light it is and it is quite a bit smaller than the 100. Some of the screens have changed but I have found that a lot of the same information is there. The screen that Greg referenced has changed a bit, but some of the information is still there. They took the arrow off and put on the HSI screen. The track, crs, gs, distance, eta, and added longitude & latitude square are on that screen. I haven't flown with it yet. So I will post more later.
| | | | | Joined: Jan 2004 Posts: 2,627 Member/2500+posts | | Member/2500+posts Joined: Jan 2004 Posts: 2,627 | Thanks Mike, anticipating your thoughts after you fly w/ it.
Greg
| | | | | Joined: Feb 2004 Posts: 10,084 Likes: 1175 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Feb 2004 Posts: 10,084 Likes: 1175 | Got my 500 a few days ago too. Wow it's so light. The 100 is a brick compared to this, and only 2 AA batteries compared to 4 in the 100. I played with it a while and I like the menus and the display on the 500. I can't wait to get home and fly with it.
Mark Buchner East Coast Outkast Fearless Leader and Cessna 150-152 Fly-In Foundation Director of Operations | | |
