#16867 04/27/05 12:34 PM
Just curious. As I search thru classifieds, I happen to notice odd numbers on engines with conflicting numbers SMOH. I'll change the numbers slightly from what was posted, but, here's one I came across....
4,324TT 310SMOH 225 since new Millenium cylinders.
Confusing here...If the engine has 310 SMOH, why would it have 225 since the TOP. To me, not proclaiming to be an engine guru but fully understanding the mechanicals of it, it seems like that issue would've been addressed at the time of overhaul while the cylinders were off?
Maybe some of the members can enlighten me on why this would've been overlooked?
Thanx in advance,
Bengie Phillips
Columbus, GA
(ps, the sample signs are on their way to Lori...sshhhh!)
Visit Put-In-Bay!!
Visit Put-In-Bay!!
Maybe he leaned too much and scorched them?
-Bryan
U.S.C.G. licensed captain
If they only flew the plane say 10-20 hrs a year it could be about 5 years or more from the major to the top. Just a possiblity.
Mike H
BAX MI
72 150L N5454Q
Hazman #16870 04/27/05 06:01 PM
Could be a typo. Could be years of inactivity.
Also, some folks overhaul the cylinders during a major
rather than replace them.
Stephen A. Mayotte
1978 Cessna R182 N7333Y
Boire Field
Nashua, NH
All valid points, but it's also possible the jugs weren't broken in right, and had to be redone. Lots of guys think you have to baby a fresh engine. Not so! You've got to run it hard enough for the rings to seat properly!
I dunno, I've seen it in several classifieds and not just the Cessna 150/152 type. It just seems mighty strange to pull it all apart again and rehone, reassemble.
I can agree with that, too. Personally, I'd rather have the new cylinders at overhaul, along with a nice set of roller rockers.... oops, they aren't approved.
Bengie Phillips
You would have to look at what year they overhauled it also. In the 80's and early 90's they didn't have the cylinders like they do now. So most would rehone and rework their cylinders. Now it is better to get the assemblied cylinders.
Mike H
BAX MI
72 150L N5454Q
