Page 1 of 4 1 2 3 4
John Hudson Tiner / P. O. Box 38 / House Springs, MO 63051
Tel: 636 677 5051
tinerj@tinerj.com
Quick Description: Cessna 150/150 (150 hp Lycoming 320 engine) and O&N Auxiliary 14.6 fuel tank, marker beacon, two VORs, glide slope, heated pitot tube, transponder and vacuum system IFR certified. Airframe TT = 4,495; Engine SMOH = 1,771. Price $27,000
N8526J Serial Number 15066426 (FAA model year 1966; Cessna model year 1967)
Airframe -- Total Time 4,495 hours (as of Oct, 2008)
N8526J Cessna 150G is a factory float plane (now on tricycle gear, no floats.)
Total internal zinc-chromate corrosion protection.
Auxiliary fuel tank 14.6 gal usable (O&N Aircraft Modifications STC SA1035NE) in baggage area
Engine
150 hp (Lycoming O-320-E2D, Serial number L-20866-27A) SMOH = 1,771 as of Oct 2008
Compression: 9-15-2008 76/80, 76/80, 79/80, 71/80
Oil Analysis: 10/1/2008 “sample appears normal”
Doyn Engine Conversion (STC SAS72CE)
Auto Gas (EAA STC SE800GL)
Bracket Air Filter (Brackett Aircraft Company STC SA71GL)
Alternator
Propeller -- McCauley IC172TM7455 (cruise)
NAV/COM
King KMA-20 audio control panel with marker beacon receiver
King KX-155 NAV/COMM Transceiver
KX 170 B NARCO NAV-COM
NARCO AT 150 Transponder with ACK A-30 encoder
Bendix/King KI-209-A VOR with glideslope and localizer head with double port for NAV/GPS
King KI-208 VOR / LOC Indicator
PS Engineering PM501 built in intercom system
Other instruments, controls, improvements
Carburetor Temperature gauge (a guide to possible carb ice)
Cylinder Head Temperature gauge
Fuel pressure gauge
Vernier lean/rich mixture control
Heated pitot tube
Seat and Shoulder Harness (Aero Fabricators STC SA1410GL)
Price: $27,000
Complete logs. I have copied the logs as *.jpg images and can send the images on a CD for review. I have flown this plane from St. Louis to Key West, FL; to Oceanside, CA; across the Grand Canyon; to Page, AZ; Devil’s Tower, WY. Always dependable. There’s not enough room in the hanger for two planes, so I’m selling N8526J so I can put the wings on the Zenith 601 XL that I’m building.
Want to know more about Cessna 150/150? Read Wayne Westerman’s article in the Cessna 150/152 newsletter Jan/Feb 203. “Everything You Ever Wanted to Know About the 150hp Conversion” Go to www.cessna150-152.com [cessna150-152.com] (I recommend joining this club if you are interested in a Cessna 150.)
John Hudson Tiner
Now this is a shocker, John!
Is everyone dumping their 150/150 to buy 150WW ? grin
John, is your Zenith 601 nearing completion?
The airframe is. I've completed everything (as separate sections) except the canopy. So I need to put it together and mount the engine and instruments.
I'm really excited about getting the 601XL finished. It will weigh about 700 pounds empty, have a max gross of 1320. With me (220 pounds), Jeanene (115 pounds), 30 gal of fuel (180 pounds), I'll still have 105 pounds for luggage. And it should cruise at about 132 mph. (Put in 25 gallons rather than 30 gallons, and it has more luggage capacity than the Cessna.) The wing loading is about the same as the Cessna, so turbulence should not be any different.
What I think is the real advantage is that I can do the condition inspection, and I can change anything whenever I want without a lot of happy hooray. I cannot mod the wings, change engine or probably not the propeller. But almost anything else I can do without a lot of paper work.
On the other hand, the Cessna 150 has given me 5 years of flawless service. If I had my druthers, I'd like to keep them both!
John Hudson Tiner
Which engine is it going to get?
Jab 3300
John Hudson Tiner
Neat, I like those Jabirus. 100+ hp in a plane that light.... fun! How about prop? Fixed, ground adjust, or electric adjust?
Wow! Two 150/150's here on the market for under $30,000!! shocked
Grants Pass, Oregon
For LSA the prop must be fixed or ground adjust. I'll probably go with whatever is in the engine kit.
I've already had a pilot from Brazil look at the N8526J. He buys small aircraft here and flies them to Brazil. He flies them by the island route, so the extended range of the 14.6 gal auxiliary tank was a plus for him. He had purchased a Cessna 150 the week before and was getting it prepped for the flight.
John Hudson Tiner
Page 1 of 4 1 2 3 4
