| | Joined: Sep 2004 Posts: 2,701 Likes: 2 Member/2500+posts | | Member/2500+posts Joined: Sep 2004 Posts: 2,701 Likes: 2 | Well, my annual inspection on the 152 revealed cracks around the hubs. They aren't bad enough to fail the annual but will probably need to be changed out soon. And, of course, McCauley hubs are no longer marketed  My brakes,bearings and axles are in excellent condition so I don't want to shell out $1000.00 plus for the Cleveland refit. Does anyone have a set of good McCauley 6" hubs they are willing to sell? Thanks! | | | | | Joined: Dec 2003 Posts: 8,433 Likes: 4 Member/7500+posts | | Member/7500+posts Joined: Dec 2003 Posts: 8,433 Likes: 4 | If this is the three piece wheel, steel flanges and die cast center hub and six allen head capscrews on each side, and the cracks are in the bolt holes, I'd be darn leery of operating the airplane with one cracked.
Charles | | | | | Joined: Jan 2004 Posts: 13,969 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Jan 2004 Posts: 13,969 |
Thanks!
Dennis, I have a set of McCauley wheels and brakes. Just trade me a Cleveland set and we'll call it square? | | | | | Joined: Dec 2006 Posts: 499 Likes: 1 Member/250+posts | | Member/250+posts Joined: Dec 2006 Posts: 499 Likes: 1 | Just a heads up on this. We have had numorous McCauley 6" hub spoke cracks of the last few years. In fact, no one that I fly with still uses them. I realize we are a little rougher on our planes up here but keep in mind, we manage to crack them while using big soft tires. Frankly, I'm surprized there is not an A.D. out on them. I have never seen one fail completely but I sure wouldn't want to be the first to see how that goes. So far, i have never found a crack in a Cleveland.
| | | | | Joined: Jul 2004 Posts: 22,841 Likes: 2740 Member/20,000 posts | | Member/20,000 posts Joined: Jul 2004 Posts: 22,841 Likes: 2740 | Dennis,
I may have a deal made in heaven for you.
If I have what you need on Queenie (The corrosion queen where Hungs engine came from) I'll be glad to swap with you. I'll need your old ones to put back on Queenie so I can move her sad carcass around. She'll never fly again so cracked hubs or not makes no difference, I just need to be able to move her around as needed.
I'm not sure what's on her now, I think they're McCauley's but I'll find out and get back to you. Stand by.
| | | | | Joined: Dec 2003 Posts: 8,433 Likes: 4 Member/7500+posts | | Member/7500+posts Joined: Dec 2003 Posts: 8,433 Likes: 4 | Just a heads up on this. We have had numorous McCauley 6" hub spoke cracks of the last few years. In fact, no one that I fly with still uses them. I realize we are a little rougher on our planes up here but keep in mind, we manage to crack them while using big soft tires. Frankly, I'm surprized there is not an A.D. out on them. I have never seen one fail completely but I sure wouldn't want to be the first to see how that goes. So far, i have never found a crack in a Cleveland. The original hubs were magnesium, and very prone to cracking, plus corrosion. Replacement hubs were aluminum. Noticeable weight difference if you held both of them, but not so prone to cracking. I suppose most of the MAG hubs are out of service, but now the years have taken their toll on the aluminum ones too. I actually submitted an article for the 150 club newsletter in the early '80's right after the club was founded, but it seems Skip Carden was more interested in publishing articles on how to do things on the cheap, and many time illegal, than publish a serious maintenance article about what was a common problem at the time. It never got published that I know of. Charles | | | | | Joined: Nov 2007 Posts: 535 Likes: 8 Member/500+posts | | Member/500+posts Joined: Nov 2007 Posts: 535 Likes: 8 | I have a set of Aluminum 3 (through)bolt aluminum Hubs. Came off a 152. They are in PA. I am currently in the Jungles of Colombia. I won't be home until the Jun Jul time frame. I might be able to get my son to mail them to you. 300.00 for the paie. they come with the brake rotor. | | | | | Joined: Sep 2004 Posts: 2,701 Likes: 2 Member/2500+posts | | Member/2500+posts Joined: Sep 2004 Posts: 2,701 Likes: 2 | Thanks to all (at least half-a dozen offers!)who responded to my request for McCauley hubs. Found a set on the field. One of the guys at Creve Coeur had switched over from McCauley to Clevelands and had tossed the hubs into a surplus pile at the back of his hangar. I didn't have to worry about shipping cost and times, and the wheels look as if they came straight out of the box.
Thanks again for all who offered - it's things like this that make this club great.
| | | | | Joined: Dec 2003 Posts: 2,134 Member/1500+posts | | Member/1500+posts Joined: Dec 2003 Posts: 2,134 | Congratulations on your good luck, Dennis. We should all be so lucky
Tim '76 C-150M, San Antonio
| | | | | Joined: Jul 2004 Posts: 22,841 Likes: 2740 Member/20,000 posts | | Member/20,000 posts Joined: Jul 2004 Posts: 22,841 Likes: 2740 | Sorry Tracey, They're McCauley's  Jim
