| Joined: Dec 2005 Posts: 2,657 Member/2500+posts | Member/2500+posts Joined: Dec 2005 Posts: 2,657 | Tilting the backrest can give you more legroom. My seat has a lever on the right hand side at the bottom, it changes the angle. Because of the landing gear passthough, the seat can not be moved back anymore.
[ Linked Image] The Turtle ( I`am slow, but I get there ) Steve `83-C152 N94270 Tracker http://aprs.fi/#!call=a%2FN94270&timerange=3600&tail=3600 | | | | Joined: Mar 2005 Posts: 291 Member/250+posts | Member/250+posts Joined: Mar 2005 Posts: 291 | Well . . . its either shorten the pilot or stretch the plane! And we know what happens when you try to stretch the plane, don't we? And its not just that it doesn't fit back into the box, either.  | | | | Joined: Jan 2004 Posts: 18,962 Likes: 3 Member/15,000 posts | Member/15,000 posts Joined: Jan 2004 Posts: 18,962 Likes: 3 | Man! Good thing Gregg's partner didn't complain about "Headroom"! Jeff Hersom: "Off with his head!"  | | | | Joined: Dec 2004 Posts: 10,735 Likes: 110 $ Member/10,000+ posts! | $ Member/10,000+ posts! Joined: Dec 2004 Posts: 10,735 Likes: 110 | Hey! I'm not complaining about headroom in a 150. I'm not complaining about any sort of room in a 150. AND I'm taller than that guy by an inch and I probably weigh more.
Jeff Hersom N3740J '67 150G "Gremlin" Hangar W-6, Helena Regional Airport Places I have landed Gremlin: ![[Linked Image from visitedstatesmap.com]](https://visitedstatesmap.com/image/ALAKFLGAIDILINIAKSKYLAMIMNMSMOMTNENCNDOHOKSDTNTXWIWYsm.jpg) | | | | Joined: Nov 2004 Posts: 5,465 Likes: 22 Member/5000+posts! | Member/5000+posts! Joined: Nov 2004 Posts: 5,465 Likes: 22 | Tilting the backrest can give you more legroom Ok, I'm sitting here scratching my head a bit and moving around on the chair a little trying to work this one out - but I'm not sure I can  I don't mean to question you on this (then again perhaps I do  ) but exactly how, will tilting the "Backrest" of your seat give you more leg room????? if your rear end is still in the same position on the seat cussion, I'm not quite sure how the space your legs reside in changes, unless you're now positioning your rear end somewhere half way up the backrest...... somehow...maybe  Cheers
Matt Gray
aerobat@cessna150pilot.com
A150K@hotmail.com
| | | | Joined: Jun 2004 Posts: 35,640 Likes: 582 DA POOBS Member with 30,000+ posts!! | DA POOBS Member with 30,000+ posts!! Joined: Jun 2004 Posts: 35,640 Likes: 582 | Jeff Hersom: "Off with his head!" Poobah: Let 'em eat cake. ![[Linked Image from animatedimages.org]](https://www.animatedimages.org/data/media/218/animated-penguin-image-0137.gif) [ animatedimages.org] Imagine a united world. Join the Popular Front for the Reunification of Gondwanaland. | | | | Joined: Mar 2005 Posts: 291 Member/250+posts | Member/250+posts Joined: Mar 2005 Posts: 291 | but exactly how, will tilting the "Backrest" of your seat give you more leg room????? Well Matt, This is exactly what I've been advocating!  As you sit in your seat, lean back and let your rear slide forward. As your toes get closer to the spinning prop, you are automaticly "trimmed to fit"! No long too tall, just exactly right!  'Course, I suppose if someone were way too tall . . . they could remove the port seat and fly from a child's seat in the baggage area Roger | | | | Joined: Nov 2004 Posts: 5,465 Likes: 22 Member/5000+posts! | Member/5000+posts! Joined: Nov 2004 Posts: 5,465 Likes: 22 | As you sit in your seat, lean back and let your rear slide forward. As your toes get closer to the spinning prop, you are automaticly "trimmed to fit"! No long too tall, just exactly right! AAhhhh, Of course...it was so obvious
Matt Gray
A150K@hotmail.com
| | | | Joined: Jun 2004 Posts: 35,640 Likes: 582 DA POOBS Member with 30,000+ posts!! | DA POOBS Member with 30,000+ posts!! Joined: Jun 2004 Posts: 35,640 Likes: 582 | Spin to trim. Gives a new definition of the ole trim wheel, huh?  Ohhhh my...  ![[Linked Image from animatedimages.org]](https://www.animatedimages.org/data/media/218/animated-penguin-image-0137.gif) [ animatedimages.org] Imagine a united world. Join the Popular Front for the Reunification of Gondwanaland. | | |
