| Anonymous Unregistered | Anonymous Unregistered | The heading indicator went out on the 150L.  Could someone steer me to a place I can purchase one? Also, need a new VOR. | | | | Joined: Nov 2006 Posts: 7,054 Likes: 99 Member/5000+posts! | Member/5000+posts! Joined: Nov 2006 Posts: 7,054 Likes: 99 | What part number directional gyro? This is from www.cessnaparts.com [ cessnaparts.com]: New: Part No. C661075-0104 GYRO DIREC $ 2,708.10 (EA) Core/Deposit of $ 3,010.00 additional EXACT SAME PART NUMBER MUST BE EXCHANGED FOR CREDIT Reconditioned: Part No. C661075-0104RX GYRO DIREC $ 1,036.45 (EA) Core/Deposit of $ 3,010.00 additional EXACT SAME PART NUMBER MUST BE EXCHANGED FOR CREDIT Wow, that's a steep deposit. Also, I doubt if the directional gyro you pull out will be the exact same part number. Can you get yours rebuilt? You need a new VOR? Do you mean the CDI indicator? Do you have one already in the plane and want to replace it with the same kind? What kind of nav/com do you have? | | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 |
| | | | Anonymous Unregistered | Anonymous Unregistered | I'm a student pilot. I'm learning in my son's 1973 150L. Last week on a cross country, the CDI wasn't moving. The To/From bar would go up and down a little, but the needle didn't move.
I'll have to check with my son to see what nav/com is in the plane currently.
Once I'm certificated (is that a word?), I'm going to be part owner of the 150L - Loosy Sue. | | | | Anonymous Unregistered | Anonymous Unregistered | Thanks, Bengie. I sent him an email.  | | | | Joined: Nov 2006 Posts: 7,054 Likes: 99 Member/5000+posts! | Member/5000+posts! Joined: Nov 2006 Posts: 7,054 Likes: 99 | Last week on a cross country, the CDI wasn't moving. The To/From bar would go up and down a little, but the needle didn't move.
I'll have to check with my son to see what nav/com is in the plane currently. Sounds like you need to have an avionics tech look at it. Welcome to the fa$$cinating world of airplane owner$$hip. p.$. When I bought my plane, the attitude indicator was crapped out. I took it to an FBO repair facility. They removed it, sent it to a place called the Gyro House somewhere here in California to have it rebuilt, and then reinstalled it. Cost me somewhere about $750. I'd be surprised if you get away much cheaper than that for either your DG or CDI problems (unless it's something easy like a loose wire or something).
| | | | Joined: Jan 2004 Posts: 4,968 Member/2500+posts | Member/2500+posts Joined: Jan 2004 Posts: 4,968 | I think there is some confusion here, so let's make sure we understand.
Newmem is describing his VOR head, not the DG.
Definately an avionics issue. Could be anything from the antenna to wiring to a bad "Nav" side of the radio to operator error.
Did you tune the Nav to the appropriate station? What was the range(distance) to the station? Could you hear the station identifier when turning up the Nav volume?
All these things would help in trouble shooting the problem. Don't assume it is the indicator, as these are pretty reliable. If you can find another Nav/Comm to swap into the panel, I would try that first as it is easy and cheap. Beyond that, get ready for a trip to your avionics shop. <img src="/ubbthreads/images/graemlins/grin.gif" alt="" /> | | | | Joined: Nov 2006 Posts: 7,054 Likes: 99 Member/5000+posts! | Member/5000+posts! Joined: Nov 2006 Posts: 7,054 Likes: 99 | Actually, Newmem mentioned that he was having problems with both his heading indicator (otherwise known as the Directional Gyro) and his VOR.
If fact the subject of this thread is "Heading Indicator."
I agree with Jeff_Davis troubleshooting methods for the VOR CDI.
An avionics tech MAY be able to help with the DG problem, as well. If not, see an A&P for the DG problem. | | | | Joined: Nov 2006 Posts: 7,054 Likes: 99 Member/5000+posts! | Member/5000+posts! Joined: Nov 2006 Posts: 7,054 Likes: 99 | Question: If www.cessnaparts.com [ cessnaparts.com] is selling the DG brand new, why are they charging a core deposit? I can understand charging a core fee for a rebuilt unit, but a new one???? New: Part No. C661075-0104 GYRO DIREC $ 2,708.10 (EA) Core/Deposit of $ 3,010.00 additional EXACT SAME PART NUMBER MUST BE EXCHANGED FOR CREDIT | | | | Joined: Jan 2004 Posts: 18,962 Likes: 3 Member/15,000 posts | Member/15,000 posts Joined: Jan 2004 Posts: 18,962 Likes: 3 | I think "New" is a misnomer when it appears on those search results. That field in the program has the label "New", and cannot differentiate between conditions. I don't think there is an input for condition. The fact that a part requires a core, illustrates to me that the unit is not new, but is in fact rebuilt (overhauled). | | |
