I am wanting to purchase a spark plug cleaner and tester. The kind I am looking for is the cabinet type that cleans as well as tests the spark plugs while under pressure. I know ATS sells them new and refirbished, but looking to save some money buying working used unit.
I used to have one for my auto shop years ago but would like one for cleaning aircraft plugs
Eric Olson
Portland, OR
N7165F 1966 Cessna C-150F
John 14:21
I’ve seen them pop up from time to time on Facebook Marketplace.
I have an ATS one you're welcome to have if you cover the shipping.
I haven't used it in years. I think the only thing it needs one of the air lines repaired on the inside the cabinet. Otherwise it works fine.
Lemme hook it up and see for sure...
Russell
Nevermind. I thought it was just that fitting on the back of the pressure gauge. But it doesn't make sparks anymore either. The balster/cleaner side is the only half that still works.
Sorry about that.
N64908 1978 152
Thank you guys, I will order a new one from ATS tonight!
And Russell, thank you for the offer and checking yours out for me.
Eric Olson
Portland, OR
John 14:21
