#674159 11/18/24 04:37 PM
Anyone have a serviceable pair of wingtips they're willing to sell? I have the symmetrical ones on my plane and I'd like to replace them with the more modern Cessna Standard ones that have that little bit of droop or cuff at the trailing edge.
N64908 1978 152
RussellJ #674163 11/18/24 05:59 PM
Look into the Knots2U wingtips. They have both the newer style wing tips and wing tips with Landing lights in the wing tips.
Ron Twente #674192 11/19/24 12:55 PM
I second this.
The factory Cessna tips are plastic and overtime deteriorate to the point of becoming useless.
The Knots2U are fiberglass and far superior the the ABS plastic that Cessna used.
As Ron noted, you will also have the option to install landing lights in the wingtip (if you so desire) which is a great upgrade that several of us here have opted for.
2 members like this: Ricky Barrette, Ron Twente
RussellJ #674195 11/19/24 01:56 PM
I will after the first of the year.
1 member likes this: RussellJ
RussellJ #674197 11/19/24 03:17 PM
A couple more pictures of the Knots2U Wing tips with the LED landing lights installed.
1 member likes this: Ricky Barrette
RussellJ #674213 11/19/24 11:42 PM
I've done the same... Knots2U fiberglass droop tips with lights. Did that in 2005 and worth every penny.
