Glad you got one.
You might need to get another backshell if they did not include the little bars to grip the cables. Very important to make sure you have solid operation of the unit.
Here is a link to one on eBay. eBay [ebay.com]
Also someone on here gave me the eBay seller wifi_expert for BNC cables. You might get lucky and the pig tail on that tray connect up then again you might not.
1973 Cessna 150L
Thanks Jason, and I do hope I am "lucky enough" to have purchased the components that will get his plane flying with a good transponder again! I am learning a lot from you and others about all the smaller components it takes to get it working properly...
Another buddy is considering donating his used but serviceable ADSB OUT unit which this transponder would work with, so things may be trending in the right direction....MTF.
Mike Marra
1977 C-150M N714AJ
Carlisle, PA. Member; Mar '07
