I have an upper and lower cowling it needs paint and has two bullet holes in it it has the landing light installed also.
Pics of the bullet holed cowl are needed. I might need this just to put in the hangar.
Experience is a hard teacher because she gives the test first, the lesson afterward. The only time you have too much fuel on board is when you're on fire.
I have the lower cowling in Tucson, Arizona; short nose with aluminum nose bowl. I don't need it but I do need the late model (fiberglass nose bowl) cowling instead.
