Page 3 of 4 1 2 3 4
Originally Posted by Shihua Zheng
https://www.aopa.org/-/media/files/...EF16BB0A17A7F98D4CF613452853B921583295BD
Page 5, EOY 2015 there were ~2000 152s registered in US, so ~1500 now sounds reasonable.
Thanks Shihua for doing the research.
If ~1,500 is close to being accurate, I have to believe that odds will be high that the majority of these could/would have high time air frames (whatever high time means)?
If true, odds would be just as high that very few would be low time air frames (again, whatever low time means)?
The questions that beg to be answered is what is high time and conversely, what would be considered low time these days???
Regardless, these 150/152's are so much fun. whistle
What's the advantage of having a 152 over a 150?
N8395M 1970 A150K
A little bit more power. A little bit faster. Not as prone to carb ice.
Can up the hp for a lot less $$ than you can for a 150.
Less chance for carb ice.
I might also add that the odds of sticking a valve in the Lycoming O-235 or O-320 is much less likely than the Continental O-200.
Why they call Lycoming sticky then...
I've never heard Lycoming called sticky.
Who is the "they" ?
Who is the "they" ?
Read it in this avweb article.
https://www.avweb.com/ownership/dealing-with-stuck-valves/
I've been in this forum for many years and have never read about a stuck valve case in a Lycoming O-235. All the stuck valve cases in this forum were in a Continental O-200.
This line in that article gives me a good laugh "Continental engine design is more resistant to valve sticking".
Who is the "they" ?
I believe that article is about big bore engines.
Originally Posted by Avweb article
Lycoming TIO-541 engines installed in the Beechcraft Duke usean oil-cooled exhaust guide. Cooling oil circulates in a groovebetween the exhaust guide and the guide boss. If this groove cokesup with oxidized oil and becomes blocked, the exhaust guide andvalve overheat and stick.
Did you miss this line?
We do see a tendency for intake valves to stick on Continental engines in the O-200,O-300 series.
As Hung said, I've been around this forum and 150's and 152's for a long while now and I think only 1 time I have heard of an 0-235 sticking a valve and numerous O-200's that have.
Page 3 of 4 1 2 3 4
