Kirk #587098 06/27/19 07:12 PM
Why does the 150 need a battery box (other than "because it was certified with it")? The 152 has a battery tray, which is easier to maintain and spot problems.
Hung #587104 06/27/19 08:47 PM
Because the original battery’s cells each had their own vent. A box was needed to capture these corrosive and/or explosive fumes and vent them safely overboard.
The 152’s 24-volt battery was a newer design that vented all the cells internally, with a single vent tube going overboard. In effect, the battery case doubled as the box.
Kirk #587126 06/28/19 02:39 PM
A Offline
I have repaired several with a fiberglass patch over the hole/holes.
New sealed batteries should eliminate the corrosion issue going forward.
Alan
Lou1981 #587197 06/29/19 11:39 PM
Kinda in the same boat but there is a solution less than a new battery and box.
This will solve future acid issues and can leave the old box with holes in it depending how big those holes are.
http://www.cessna150152.com/forum/ubbthreads.php?ubb=showflat&Number=420626#Post420626
https://www.aircraftspruce.com/catalog/elpages/odysseydry9.php
https://www.aircraftspruce.com/catalog/elpages/odysseydry7.php
Hung #587212 06/30/19 03:33 AM
Pre 1980 152s have battery boxes.
