A Offline
Searching for a friend.
A "Flange Shaft" Crank and a Cam Shaft for an 0-200
Anybody?
Antonio Bal
A "virgin" = original dimensions crankshaft is the hardest to find and most desirable used crankshaft. Beware of your sources as there are parts sharks selling steel parts such as rebent cranks.
"Virgin" crank would imply un-used in my books, standard dimensions would be used, but polished only - not ground to M010 or M020 due to wear. Never heard of a "rebent" crank - but knowing what I know about Continental crankshafts, if you bend and then re-bend one, it's likely to be cracked. I can't imagine any reputable shop tagging such a crankshaft.
Last time I called a barnstormer's ad regarding crankshafts for an O200, he said there aren't many out there. Whenever he lists one for sale it sells almost immediately.
PM sent Anthony... I might be able to help out.
Getting input from some sources that there's a shortage of cranks for the small Continentals. Anyone run across this?
That's what I've found.
When I had my O-200 overhauled in 2010 I had to spring for a new crankshaft. Overhauled ones were simply unavailable.
Does anyone know whether or not new cranks are available? Just for future reference. I hope I don't need one.
I believe new ones are available...
http://www.aircraft-specialties.com/o-200-crankshaft-653012/
$4550 with return of an unserviceable core. No core? Add $1000.
eek
Whoa!
A Offline
Response to PM sent to Steve A.M. Thanks!
Antonio Bal
Wonder what they do with an unservicable core to make it worth $1,000.00?
Philip Mitchell
Attorney, CFI, A&P
N150BP C150L
