Page 2 of 3 1 2 3
Originally Posted by Gerardo_Martinez
That's a link to the pictures. I can't find the ad with a search.
Bruce Bennett
Visited
Found it
https://www.barnstormers.com/classified_1115962.html
Bruce Bennett
Visited
sorry just realized it
Found it
I'm not sure if this engine would be legal for installation in certified aircraft. I hope someone with better knowledge in this will chime in. What I've been told is that if a certified engine is installed in a experimental aircraft, it cannot be used in certified anymore. The engine in the link is currently installed on what I believe is a kit gyrocopter.
1968 150H N5005
1969 Pitts S-1C
1970 150H Super Heavy wink
Since the engine has its own logbook, I would think it still retains its 'official' certification so long as it was maintained in accordance with the FARs.
Who told you that?
Something type certificated doesn't lose that certification merely by its use or installation on a non certificated ( experimental ) airframe.
Who told you that?
I was told by an A&P. Why are some certified engines referred as experimental? Other then using none PMS'd parts is there anything else that can make it experimental?
1968 150H N5005
1969 Pitts S-1C
That A&P was wrong. You can put a certified engine on an Experimental airplane. That does NOT make it an Experimental engine, it is still a certified engine and susceptible to ADs and such.
This one just popped up on EBAY [ebay.com]
James Rhoades, A&P/IA
5729E '59 150TD "BarFly"
N76040 '46 120 SOLD
Page 2 of 3 1 2 3
