Page 2 of 3 1 2 3
Fuel starvation.
Originally Posted by Mark_Silverman
The Cessna Aerobat Spin video raised a question. I take it that stopping the engine during a spin is not SOP. Would you mind explaining what happened?
It's actually in the POH. Words to the effect that 'during prolonged spins with half tanks or less, engine stoppage may occur. But this does not adversely affect spin recovery.'
What happens is the fuel slugs outboard, uncovering the pickups in the tanks. I think Catherine said it takes about 13 turns before the engine will stop.
The engine in a 150 tends to stop after 5-6ish turns. In a 152, it tends to be in the 13-16 range.
Facts I would never ever have known! My limit is 1/2 a spin. Is 1/2 a spin technically a spin??
Does "prop windmilling" restart the engine?
Terry Monday
1976 C150M N9463U
Greenville, NC
It sure does! The cylinder doesn't know or care if the stater motor is turning the crank, some meat bag pulling on the prop, or the wind rushing past the prop.
One needs to direct that question to someone with experience.......I'd ask Poobs. sick
The answer is a (screaming) yes. sick
So the prop continues to turn after the 13th (that's unnatural) spin but the engine dies due to lack of fuel. The engine re-starts when fuel flows to the engine once the spinning has stopped?
Terry Monday
1976 C150M N9463U
Greenville, NC
Usually. Sometimes the prop stops windmilling since a spin is a relatively low-speed event. Diving after the spin recovery gets the prop spinning again.
Sold!
On the way to Paraguay, in the southern hemisphere the direction of spins will be opposite my video.
Page 2 of 3 1 2 3
