Here is an image from interenet of what you should have on your gear leg, on the backside of the wheel. It sandwiches between the gear leg and wheel spindle when the 2 are bolted together.
Originally Posted by Matt_Luce
My plane didn't come with pants. How can I tell if I have the plate and if I don't where do I get it? I have a 1967. These should fit right?
Start by looking in your PARTS MANUAL. grin Then compare the illustration to your aircraft.
I don't have that part. Don't suppose you already have the brackets or did you already say it's not included.
1967 Cessna 150G
Lifetime Member
2016 & 2019 Top Gun Pilot
I have one main gear mounting plate that came on my plane, and I think I have a set of the proper wheel nuts.
1967 C182K
Matt,
Suggest you go back 5 messages and re-read the post where he said:
No damage. You will need the mounting plates on your mains to attach then to, and the correct spindle nut.
grin
Last edited by Barney_Kemter; 05/23/15 03:05 AM. Reason: sarcastic comment removed.
Dammit Barney !! There you go with that "manual" thing again. Takes all the adventure cunning and creativity out of the equation. laugh
Blue Skies,
Gene
N5977J
Originally Posted by Barney_Kemter
Matt,
grin
Right. I forgot. So I guess I'm looking for a set of mountng plates and spindle nut.
1967 Cessna 150G
Lifetime Member
Spindle Nuts HERE
