#474988 05/03/15 10:01 AM
Hi,
i need for my 1967 Reims Cessna 150H spare parts.
Main Landing Gear
0441186-1 Spring assy.LH
0441186-2 Spring assy.RH
0441169-1  Step bracket LH
0441169-2 Step bracket RH
Wheel
161-31 Wheel half-male
162-28 Wheel half-female
Flaps rails left and right
523231 Rib Assy.
steffen from Germany
Welcome, Steffen!
Welcome Steffen!
Use these PMA new parts:
http://www.mcfarlane-aviation.com/Products/?PartNumber=MC0525001-2
With all the work involved in putting in the flap tracks it is just not worth putting in used parts here.
Helping my mechanic the whole job to replace them on both sides took us 8 hours. (2 people x 8 hours + 16 man hours)
We also put in the roller kit at the same time - again - while you have it all apart - you just have to do it:
http://www.mcfarlane-aviation.com/Products/?CategoryID=54&PartNumber=MCSK100&
Good luck with the spring gear - that is getting harder to get. Try the junk yards. Last time I did the springs cost me $115 each. They came with the steps still on them.
I just paid 125 each for a pair. No steps, but the brackets are there. Freight cost me 100 bucks extra. My old ones have some pitting that I didn't like.
J. W. Palmer
1970 C-150K N6272G
Ashland, VA (KOFP)
States where I have landed so far...
Thank you for the warm welcome
and all the tips I get via email and from the forum
i get a weel and the PMA Flap rail parts are perfect, still looking for the gear...
At the junk yards in Germany i may find some old Dodge parts from 1967 but they haven't got cessna parts....:-)
Steffen
Will a 1964 D model gear legs work on the H? I dont have a parts manual handy..but I have gear legs for a 64D model in my possesion wink
Yes! If my research is correct, according to the parts manuals, 1961 150A thru 1970 150K/A150K models use the same gear leaf springs, 0441186-1 (LH), and 0441186-2 (RH). 1971 and up used round gear legs.
Subject to verification!
Jim, My parts manual shows the flat spring gear as:
PN 0441186-1 LH
0441186-2 RH
Code A serial #s 15071129 thru 15072003
D series S/N's 15060088 thru 15060772
H series S/N's 15067199 thru 15069308
Hope this helps.
BK
PN 0441186-1 LH
0441186-2 RH
Hope this helps.
BK
That's from the 1970-1977 manual. The 1959-1969 manual shows the same part numbers from 1961 thru 1969.
PN 0441186-1 LH
0441186-2 RH
Hope this helps.
BK
I was checking my other parts manual while Carl was posting, same info as he posted. grin
Carl and I must have 2 of the 6 parts manuals in existence... wink
