| Joined: Jul 2014 Posts: 5 Member | Member Joined: Jul 2014 Posts: 5 | Hi, i need for my 1967 Reims Cessna 150H spare parts.
Main Landing Gear 0441186-1 Spring assy.LH 0441186-2 Spring assy.RH 0441169-1 Step bracket LH 0441169-2 Step bracket RH Wheel 161-31 Wheel half-male 162-28 Wheel half-female
Flaps rails left and right 523231 Rib Assy.
steffen from Germany
| | | | Joined: Jun 2006 Posts: 7,146 Likes: 204 Member/5000+posts! | Member/5000+posts! Joined: Jun 2006 Posts: 7,146 Likes: 204 | | | | | Joined: Jun 2011 Posts: 19,214 Likes: 2348 Member/15,000 posts | Member/15,000 posts Joined: Jun 2011 Posts: 19,214 Likes: 2348 | Welcome Steffen! Flaps rails left and right -------------------------- Use these PMA new parts: http://www.mcfarlane-aviation.com/Products/?PartNumber=MC0525001-2With all the work involved in putting in the flap tracks it is just not worth putting in used parts here. Helping my mechanic the whole job to replace them on both sides took us 8 hours. (2 people x 8 hours + 16 man hours) We also put in the roller kit at the same time - again - while you have it all apart - you just have to do it: http://www.mcfarlane-aviation.com/Products/?CategoryID=54&PartNumber=MCSK100&Good luck with the spring gear - that is getting harder to get. Try the junk yards. Last time I did the springs cost me $115 each. They came with the steps still on them. | | | | Joined: Mar 2014 Posts: 387 Member/250+posts | Member/250+posts Joined: Mar 2014 Posts: 387 | I just paid 125 each for a pair. No steps, but the brackets are there. Freight cost me 100 bucks extra. My old ones have some pitting that I didn't like.
J. W. Palmer 1970 C-150K N6272G Ashland, VA (KOFP) [ Linked Image] States where I have landed so far...
| | | | Joined: Jul 2014 Posts: 5 Member | Member Joined: Jul 2014 Posts: 5 | Thank you for the warm welcome
and all the tips I get via email and from the forum
i get a weel and the PMA Flap rail parts are perfect, still looking for the gear...
At the junk yards in Germany i may find some old Dodge parts from 1967 but they haven't got cessna parts....:-)
Steffen | | | | Joined: Jan 2007 Posts: 3,640 Likes: 49 Member/2500+posts | Member/2500+posts Joined: Jan 2007 Posts: 3,640 Likes: 49 | Will a 1964 D model gear legs work on the H? I dont have a parts manual handy..but I have gear legs for a 64D model in my possesion
Delta Pilot Ghetto KFFC Falcon Field N378T
| | | | Joined: Jan 2004 Posts: 18,962 Likes: 3 Member/15,000 posts | Member/15,000 posts Joined: Jan 2004 Posts: 18,962 Likes: 3 | Yes! If my research is correct, according to the parts manuals, 1961 150A thru 1970 150K/A150K models use the same gear leaf springs, 0441186-1 (LH), and 0441186-2 (RH). 1971 and up used round gear legs.
Subject to verification! | | | | Joined: Oct 2007 Posts: 2,600 Member/2500+posts | Member/2500+posts Joined: Oct 2007 Posts: 2,600 | Will a 1964 D model gear legs work on the H? I dont have a parts manual handy..but I have gear legs for a 64D model in my possesion Jim, My parts manual shows the flat spring gear as: PN 0441186-1 LH 0441186-2 RH Code A serial #s 15071129 thru 15072003 D series S/N's 15060088 thru 15060772 H series S/N's 15067199 thru 15069308 Hope this helps. BK | | | | Joined: Jan 2004 Posts: 18,962 Likes: 3 Member/15,000 posts | Member/15,000 posts Joined: Jan 2004 Posts: 18,962 Likes: 3 | Will a 1964 D model gear legs work on the H? I dont have a parts manual handy..but I have gear legs for a 64D model in my possesion Jim, My parts manual shows the flat spring gear as: PN 0441186-1 LH 0441186-2 RH Code A serial #s 15071129 thru 15072003 Hope this helps. BK That's from the 1970-1977 manual. The 1959-1969 manual shows the same part numbers from 1961 thru 1969. | | | | Joined: Oct 2007 Posts: 2,600 Member/2500+posts | Member/2500+posts Joined: Oct 2007 Posts: 2,600 | Will a 1964 D model gear legs work on the H? I dont have a parts manual handy..but I have gear legs for a 64D model in my possesion Jim, My parts manual shows the flat spring gear as: PN 0441186-1 LH 0441186-2 RH Code A serial #s 15071129 thru 15072003 Hope this helps. BK That's from the 1970-1977 manual. The 1959-1969 manual shows the same part numbers from 1961 thru 1969. I was checking my other parts manual while Carl was posting, same info as he posted.  Carl and I must have 2 of the 6 parts manuals in existence... | | |
