Keith -- I'll try to locate some paperwork on them.
They're no help in fueling, since there's nothing to hold onto when fully up on the step -- it could be done but would be tricky. I did use them once for fueling at an automotive station at Denio Junction NV from six gallon fuel cans. Hoisting them up and keeping my balance was a tedious and marginal project. What they're really handy for is dumping the fuel from the Gats jar and checking fuel level. Also for checking to make sure the caps are secure after getting fuel from a truck.
Roy
[Linked Image from eznec.com]
Originally Posted by Keith_Wood
I'm ambivalent about the steps. I would put them on, but only use them if a ladder were not available. I wouldn't take them OFF ("drag reduction"? REALLY? wink ).
Hey... every little bit helps. smirk
Originally Posted by Roy_Lewallen
I'm sure that any improvement caused by removing them will be due entirely to placebo effect. That is, of course, nothing to be sneered at -- it's a well established performance enhancement mechanism as verified by many testimonials.
Roy
probably quite true.
K Offline
I've been to "Denial Junction," but never bought fuel there. The last time was after overflying Geek Week (er, I mean "Burning Man") and Soldier Meadow a year or so ago.
The last time I climbed on steps on a 150, I stuck fingertips into the recess around the gas cap for the last part of the climb. That was a few decades ago.
Originally Posted by Steve_A.M.
I'm contemplating removing mine... for drag reduction. I use a little ladder for fueling anyway.
That and the weight savings....you could probably add an extra quart of fuel when things are tight on the gross weight front?? smirk grin
Hah... Exactly!
crazy
W
W Offline
A quart of oil and this kit weigh the same, 1 lb 13 oz.
Weight increase....pooey....put an O320 in your machine;-)
Or, DOUBLE you fun and pleasure with two of 'em! laugh
The Rourke Rocket!
(You're halfway to it, Bill!)
W
W Offline
The kit has been sold..
