Jim,
You'll have to pester the new owner about that.
Hmmmmmmmmmm, there seems to be a message you're trying to send us in your statement..........Kandace?????
Rick, the nose gear is run off one output arm of the gear transmission and the mains from the other.
Kendel,
That is correct - and you cannot rig just one arm off of the gear transmission on the Cessna electro-mechanical gear and be assured that you have not affected something on the other two. Trying to do so is one of the causes of gear collapses and hang ups on that system. The rigging process starts at the center of the transmission and progressively works outward on all three arms.
Warmest regards,
Rick
Given it's not been rigged in the last seven years, I think a full rigging would be in order before cycling the gear in flight. I've seen the results of a nose gear failure. Even the most gentle of landings still usually results in a death sentence for the poor 310 because of the amount of damage that gets done with the props hitting the ground.
Wondering what the final result was for this sale. Updates PLEASE!
K Offline
I did purchase the airplane.
Kandace
P.S. I have had a change of heart and have decided to sell it.
I put it on Barnstormers yesterday.
Kandace Rawling
C150K
N5774G
why the change of heart? is it too big of a project? Did you ever get a chance to ferry it?
K Offline
I don't think it is too big a project. No I did not ferry it, it is still in AZ.
I'm going in another direction that is all.
Kandace Rawling
C150K
N5774G
I'm assuming you've seen the aircraft and if I remember correctly you are an A/P. How much do you think it would take to get it in turn key condition ot including paint. or cosmetics. Just a reliable flying aircraft?
K Offline
I would say as a guess..... Including the props it would be in $10,000 range.
It needs batteries, tires, a strut leak fixed, a gear rigging and a general going over.
Kandace
Kandace Rawling
C150K
N5774G
