Page 3 of 5 1 2 3 4 5
Alan Core #393912 03/20/13 11:25 AM
There was an aileron on eBay a couple of days ago - though I can't find it now - so maybe it is gone.
That slight upward wash out on the aileron is to help slightly counter the tendency of the aileron to cause drag in a turn. Without it you would use some more rudder to stay coordinated.
Wheel pants - you could just take them both off......
Graeme Smith #393916 03/20/13 11:35 AM
Somewhere, someone once said, legal wheel pant removal:
Remove all (3) or none.
Bengie Phillips #393933 03/20/13 02:10 PM
So, I guess you have to take your pants off completely or not at all to fly? shocked
Guess Gary was right all along! eek grin
Ed Pataky #393960 03/20/13 05:48 PM
I think the issue would be you should do a weight and balance to account for which version of the pants you have configured - rather than a blanket ON or OFF. It is not like they are on a MEL.
I'm probably missing something?......
Graeme Smith #393993 03/20/13 11:22 PM
P
P Offline
Just out of interest Amy, does your airplane stall straight ahead or drop quickly off on one wing?
I'm of the get if fixed school. If an airplane won't fly straight and level, hands off, there's something that needs to be fixed.
These airplanes left the factory flying right and we should keep them that way.
Paul
C150F C-GCKJ
Paul_Knapp #393996 03/21/13 12:08 AM
Amy_White
Unregistered
Amy_White
Unregistered
I will take some pics next time I'm at the airport. smile
Yes, my airplane stalls straight ahead. But you have to be on top of it. Or else, many times, one wing drops slightly.
Alan Core #393997 03/21/13 12:11 AM
Amy_White
Unregistered
Amy_White
Unregistered
Originally Posted by Alan_Core
... is the wing tip straight?
Not straight. Just bent outta shape so that it hangs below the tip when all other points are lined up.
#394000 03/21/13 12:28 AM
Amy
I would have to agree with Kendel, why not reskin it? If I have learned anything from my project, it is that you never know for sure what you get with used parts. I looked on McFarlane and precut replacement skins are reasonable. When you got done, you would not only know what you have but could also get the experience of doing it(with your mechanics help). wink
James Rhoades, A&P/IA
5729E '59 150TD "BarFly"
N76040 '46 120 SOLD
James Rhoades #394005 03/21/13 01:08 AM
Originally Posted by Amy
I need an aileron before I go to take my checkride.... smirk
I think it would be quicker to replace the damaged aileron so Amy and her Mom
can get on with their training and get the checkride done.
Graeme Smith #394007 03/21/13 01:10 AM
Technically, the wheel pants are listed as a single line-entry on the option sheet from Cessna, with a single W&B figure for all three pants. Therefore, they can only be installed or removed as a set.
