Page 2 of 5 1 2 3 4 5
I looked at my ailerons last night. Both bend slightly upward at the outer end (end near wing tip). Maybe an 1/2 inch. Both bends were exactly the same.
Is this normal?
Wish there were a couple of 150's at PGV I could look at for comparison. Can't wait for Clinton so I can see what other people have done to their planes.
This forum makes you really, really look at your plane!
Good luck Amy. Let me know if there is anything I can do to help. Can't keep Vi out of the air but so long!
Terry Monday
1976 C150M N9463U
Greenville, NC
Terry Monday #393524 03/17/13 02:13 PM
Is this normal?
I believe so. At least, my old 150 was the same way.
Terry Monday #393534 03/17/13 03:56 PM
Amy_White
Unregistered
Amy_White
Unregistered
Is this normal?
I think it is. smile My left one does, but my right is bent more unnaturally.
Thanks! I can't fly anyway until I get the left wheel pant back on. Much to my dismay, about a week ago I saw a small crack and big chunk missing near the bottom. cry (I likened to have thrown a hissy-fit... smirk )It's off getting fixed by a friend right now. I think I'll leave it off until I get the re-treads on there. So I don't have to put it on to take it off again. crazy
Terry Monday #393551 03/17/13 06:47 PM
Is this normal?
Yes. And on a 172/182 also. No worries.
Ed Pataky #393728 03/19/13 12:11 AM
Amy_White
Unregistered
Amy_White
Unregistered
I looked at my airplane today. It looked crippled or something with one wheel pant off!!! grin tires should be here soon.....
Oh right! The aileron.... Yes. I looked at the aileron. There is definitely a crack where the dent is, and it has been stop-drilled. My CFI doesn't think that's allowed. SO.
We have one in our sights for 300 bucks. Does that sound reasonable? smile
#393738 03/19/13 01:14 AM
Yes.
Ed Pataky #393740 03/19/13 01:51 AM
Your prop looks fine Amy. Looks like just a bit of peeling paint. Would not worry about it. I'm really surprised the bend in that aileron wont respond to a little elbow grease!
Jim C #393742 03/19/13 02:11 AM
Gotta agree with Gary and Jim....prop is cosmetic and the aileron is airworthy. don't wast your money; get your license and bring her to Clinton.... We can either break it ( and then fix it) or fix there;-)
Bill Rourke #393748 03/19/13 03:36 AM
$300 is not a bad price but you could replace that skin for less than $100. I don't mean pay someone else to replace it but have the great experience of learning to drive a rivet yourself. Of course, that can lead to a life long problem of accumulating tools and is not recommended for everyone. Sure is fun though.
#393881 03/20/13 03:12 AM
A Offline
Amy
Have your mechanic check the Cessna structural repair section of the maintenance manual, section 19-40. If the crack is across the corrugation and doesn't go to the trailing edge then it needs to be fixed as soon as practible.
It can be repaired with a patch inside the aileron pretty easily but you would need to remove it to check the balance.
The ailerons have a bow in them about 2/3 of the way to the tip, is the wing tip straight? Alan
