Page 2 of 8 1 2 3 4 5 6 7 8
Bruce B #381446 12/05/12 11:17 AM
That would be my recommendation as well. I have the Verizon 1GB plan and come pretty close each month. I purposely don't download YouTube or other video while on cell data. (And on any 4G network you could sure get to 1MB quick)
Also...a lot of GA airports I've been to are not in the most populated of areas. I feel better with the better coverage.
Disclaimer: I work for Verizon (not the cellular side of the house) and think they rock where the network is concerned. So my opinion is biased, but Consumer Reports agrees with me grin
I know each option...(more memory and cellular enabled) adds to the cost now, but trust me you won't regret it! grin
Sandy
A150M TD N9832J "Sassy"
Sandra Newfang #381454 12/05/12 12:10 PM
W
W Offline
My two cents: wifi/cellular version with the gps built in, buy as much memory as you can afford, either Verizon or AT&T version but don't signup for the service (you can buy it by the month when you need it; and a Dual GPS rounds out the ticket ...
Walt
Red_Harrell #381455 12/05/12 12:15 PM
Originally Posted by Red_Harrell
I deliberately did not choose a 3G version because I don't really need a monthly data plan which with my currant provider, AT&T would cost me $360 per year. Also I have WiFi at my house and free WiFi is available at the airport.
I plan to adapt the iPad to my existing PC mount that I have on my yoke.
You are not required to get a data plan with the 3G version. The 3G version gives you a built-in GPS, in addition to the 3G capability. They usually cost about $139 more than the WiFi only model, so not much more than buying an external GPS and you then have the option to turn on data in case you need it in a pinch.
The built-in GPS has worked very well for me.
I got my 3G iPad strictly for the GPS. However I made the mistake of trying out the data plan one month and could not turn it off afterwards. It is just too convenient for me. Where I live, and for traveling internationally, I find AT&T better because they use thee GSM system. I also have my phone with AT&T because I can use date and phone simultaneously. Coverage where I live is just as good as Verizon.
You'll have time to decide how much data you'll need. You can easily change plans from one month to the next.
Merry Christmas, Amy!
Henry
N2011X - 1965 C182H
Walt_George #381456 12/05/12 12:28 PM
Originally Posted by Walt_George
My two cents: wifi/cellular version with the gps built in....and a Dual GPS rounds out the ticket ...
Why do you need the external Dual GPS if you already have the built-in GPS?
Hung #381459 12/05/12 12:46 PM
Because the internal GPS works fine in my 150, but it does not in my 747. So I also have a DUAL external GPS. I also have an external ADS-B GPS that I use in the 150.
Mark #381460 12/05/12 01:10 PM
Is that because of the mounting location in the 747 or the altitude?
Sandra Newfang #381461 12/05/12 01:33 PM
I'm going to have to agree with Sandy here. My iPhone is on AT&T and my iPad is on Verizon. There have been many times when I have signal from Verizon but not with AT&T. Most often that happens to be at an airport, since they are generally on the edge of town and not close to the population centers where the cell towers are usually located.
I have the smallest data plan, and it seems to work fine for me. The iPad data plans work differently than the normal cell phone plans do. It is basically month-to-month, no year (or more) commitments. You can turn it on when you need it and off when you don't (although you will probably end up leaving it on all the time). You can also up your data plan if you are starting to run out, even if it is in the middle of the month.
John
'81 C-152
N6298M
Hung #381462 12/05/12 01:35 PM
Probably mounting location. I had a pretty good GPS signal from the back seat last month. I went on to FlightAware before the flight and entered the assigned flight plan into my iPad. Then I could watch all the changes to the flight plan in real time. It was pretty cool, although I did have a window seat.
John
'81 C-152
N6298M
Henry M #381469 12/05/12 02:51 PM
Amy_White
Unregistered
Amy_White
Unregistered
Merry Christmas! smile
I see a lot of you are for verizons 1GB for $20.00 plan. But since (as you said) I can easily change plans from month to month, I think I'll give AT&T a try. And if I find myself in need of more data, I'll go with Verizon. Because 4 times the data for 5 more bucks is a LOT. Not to mention better coverage.
So more than likely I will end up switching.
YOU USE AN IPAD IN A 747!!!??? I thought that thing would be loaded down with so many GPS's you wouldn't even need anything else! shocked
#381470 12/05/12 02:56 PM
Because Mark can't watch YouTube videos on his 747's GPS's. grin
