#363879 07/12/12 03:50 PM
TAILDRAGGER 152 • $39,000 • FOR SALE OR TRADE • Taildragger 152 Experimental with Lycoming O-235 - 118HP, 110hrs SMOH - 1850 lb Gross >700 lb payload, 3 bladed prop, tuned exhaust, long range tanks, Horton STOL, Garmin 430 WAAS($$!!), Garmin MX20 MFD, Garmin 327 Transponder, intercom. Brand New upholstery, Custom Paint!! Great all metal taildragger!! W
http://www.barnstormers.com/listing.php?id=657941
Is it YELLOW though?
1850 pounds MGW? With a O-235?
Wonder what limitations are on the Experimental certificate...
Ya, but his Va must be around 125kts. wink
Is that US, or CA dollars?.......with all due respect, seems a tad pricey in this economy, nobody here would give you a loan at that price...
One of the experts will correct me I am sure, but I thought I read you could only use the experimental moniker on certified for development purposes and when done, it had to be returned to standard.
Somebody may be buying an expensive boat anchor if they are not careful. (again....I may be wrong on this one)
I think you are correct, Jeff.
John
'81 C-152
N6298M
