Used to belong to Jim Borgman, who hasn't posted since October 2008. The current owner isn't Jim, and looks like it was only registered this past November. One of the two should know what happened to the logs (if there's not somebody in between them... it appears it still had logs in 2006). You'll need the original registration number to get the right FAA CD. The current registration shows the Cessna, but the FAA info for that reg is about a crashed PA-28 that used to have that reg.
You might still be able to contact Jim at jimbenterprises@yahoo.com if that hasn't changed.
