| Joined: Sep 2007 Posts: 757 Member/750+posts | Member/750+posts Joined: Sep 2007 Posts: 757 | I have a pair of 152 Long range wing for sale sans aileron/flaps/flaps motor (just the wing). They come from a wind damaged airplane, left wing is beyond repair (spar is bent), right wing has wrinkle at the two end ribs. Both long range tanks are intact. Right panel cover has minor ding, left panel cover will need a patch around a hole, just near the spar/carry thru attachment (you can see in the first picture where the spar was bent). Also if you don't want to drive here to pick up the wing, I can remove the tank, strap, panel cover, or even cut the wing outside the last tank rib and crate/strap on a pallet/ship, if someone wants to modify their existing wings ala Del Air style. Will work shipping with the buyer/ ship anywhere. Asking 1000$ each. [ Linked Image] left [ Linked Image] right [ Linked Image]
| | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | Fred, Not that I'm in the market, but a question does come to mind:
Do you think they're factory long-range tanks or do they appear to be the Del-Air conversions?
| | | | Joined: Sep 2007 Posts: 757 Member/750+posts | Member/750+posts Joined: Sep 2007 Posts: 757 | Bengie Yes they are factory long range.
Fred
| | | | Joined: Nov 2007 Posts: 535 Likes: 8 Member/500+posts | Member/500+posts Joined: Nov 2007 Posts: 535 Likes: 8 | [quote=Frederic_Arpin] left wing is beyond repair (spar is bent),
Nothing is beyound repair! May concern is it cost effective to repair. | | | | Joined: Jan 2004 Posts: 13,969 Member/10,000+ posts! | Member/10,000+ posts! Joined: Jan 2004 Posts: 13,969 | Fred, Not that I'm in the market, but a question does come to mind:
Do you think they're factory long-range tanks or do they appear to be the Del-Air conversions? A quick reference way of telling the difference is look at where the fillers are. Converted standard tanks have the fillers in the middle of the tank. I hope that this helps....... Bill Grants Pass, Oregon | | | | Joined: May 2005 Posts: 1,157 Member/1000+posts | Member/1000+posts Joined: May 2005 Posts: 1,157 | If anybody can confirm the tanks will work in the 150M...Sandy and I are interested,
Dan A150M TD; N9832J "Sassy"
| | | | Joined: Jan 2004 Posts: 13,969 Member/10,000+ posts! | Member/10,000+ posts! Joined: Jan 2004 Posts: 13,969 | Danny, If you are looking to convert standard wings to long range tanks. You may want to do a little research first. It is quite an extensive modification.
Bill Grants Pass, Oregon | | | | Joined: Dec 2004 Posts: 3,693 Member/2500+posts | Member/2500+posts Joined: Dec 2004 Posts: 3,693 | Hey Bill, We're sure it's a ton of work. Thinking we'll change tanks with the O-320 conversion. We welcome any thoughts or scary findings you've discovered and can share! Fortunately we have a good friend as our A&P / IA and he's very helpful too.
Another bonus....LuluBelle should be in good shape at that point and can carry our butts around while Sassy gets her makeover.
Sandy A150M TD N9832J "Sassy"
| | | | Joined: Dec 2003 Posts: 14,801 Likes: 552 Member/10,000+ posts! | Member/10,000+ posts! Joined: Dec 2003 Posts: 14,801 Likes: 552 | Danny, If you are looking to convert standard wings to long range tanks. You may want to do a little research first. It is quite an extensive modification.
Bill Grants Pass, Oregon Probably not much worse than the corrosion repair on Lulubelle's wings.
| | | | Joined: Dec 2006 Posts: 499 Likes: 1 Member/250+posts | Member/250+posts Joined: Dec 2006 Posts: 499 Likes: 1 | I believe all 152's had the forward and aft fuel lines coming from the tanks. The M 150 still had the old single drain piont near the center so you would be doing some feul line modifications inside the plane in order to use these tanks.
