Page 5 of 6 1 2 3 4 5 6
Thanks! AND he indicated "OBO"...wondering what should I offer? Obviously a lot has to happen, but it is very intriquing. Looks like the plane is in California...long way from Indy...
Looks pretty good Brian. There are some dings and missing paint but no more than you would expect in a plane of that age.
I would want to know who did the "major overhaul" and what was done. With only 124 hrs since major it should have 28° timing - I would check on that.
The panel area looks clean but there is no picture of the rest of the interior; wonder what it looks like.
How close/far is it between you and the plane. I would want to look at it pretty closely before making an offer.
Looks like it could make a nice starter plane.
I thought that the area code went to Minnasota? Where in California is it?
Ok, thoughts an opinions on this one located in my backyard:
http://www.barnstormers.com/classified_files/5/3/2/4/9/0/532490-N18050_Info-Spec_sheet.pdf
Looks Clean.
I would call on this one for sure.
Brian: I have quite a bit of time in that airplane. It used to be in West Memphis back when I was learning to fly.
Stacey: Wow, that's pretty neat! Hopefully it still flys straight and true as the ad indicates. Looks like IFR?? Hoping to take a closer look early next week.
That looks like it might be a great buy. I would definitely look in to that- funny how the one you end up with was local all along!
I am cautiously optimistic!!
"Annual Inspection Due: August 2012" ? That plane must be ahead of our time. confused
