Don't know how much effort to put into splitting the strut fairings. It takes less then 15 minutes to change them by just removing the wing root inspection cover, loosen things off a tad, and then take out the bolt holding the strut to the wing. There's enough give in all else to just push the wing up a bit and then pull the fairings off and replace. Sounds complcated, but my AME and I did both sides in about 30 minutes or so. I've done the same on 172's and they're just as easy.
