| | Joined: Dec 2005 Posts: 1,669 Likes: 11 Member/1500+posts | | Member/1500+posts Joined: Dec 2005 Posts: 1,669 Likes: 11 | Life goes on but it is decision time in the next two years. | | | | | Joined: Jun 2004 Posts: 36,114 Likes: 776 DA POOBS Member with 30,000+ posts!! | | DA POOBS Member with 30,000+ posts!! Joined: Jun 2004 Posts: 36,114 Likes: 776 | Powered parachute in exchange for Mighty Mouse??? ![[Linked Image from animatedimages.org]](https://www.animatedimages.org/data/media/218/animated-penguin-image-0137.gif) [ animatedimages.org] Imagine a united world. Join the Popular Front for the Reunification of Gondwanaland. | | | | | Joined: Dec 2005 Posts: 1,669 Likes: 11 Member/1500+posts | | Member/1500+posts Joined: Dec 2005 Posts: 1,669 Likes: 11 | Not sure but it will be a light Sport qualified. Did not buy the PP. | | | | | Joined: Sep 2004 Posts: 2,701 Likes: 2 Member/2500+posts | | Member/2500+posts Joined: Sep 2004 Posts: 2,701 Likes: 2 | (INSERT LSA HERE)..in exchange for Mighty Mouse??? On no, Dale... SAY IT AIN'T SO!  | | | | | Joined: Mar 2004 Posts: 12,760 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Mar 2004 Posts: 12,760 | EXCELLENT!!!!! Good choice.
| | | | | Joined: Apr 2005 Posts: 9,831 Likes: 142 Member/7500+posts | | Member/7500+posts Joined: Apr 2005 Posts: 9,831 Likes: 142 | LSA or Experimental!!!!!
Get away from the freakin' certificated aircraft issues...
Gary Shreve When writing the story of your life, never, ever let someone else hold the pen. [ Linked Image] | | | | | Joined: Dec 2005 Posts: 1,669 Likes: 11 Member/1500+posts | | Member/1500+posts Joined: Dec 2005 Posts: 1,669 Likes: 11 | It will be something I can work on without the BS and still fly without a medical. Open to suggestions. | | | | | Joined: Aug 2007 Posts: 4,797 Member/2500+posts | | Member/2500+posts Joined: Aug 2007 Posts: 4,797 | It will be something I can work on without the BS and still fly without a medical. Open to suggestions. Vans RV-12 [ vansaircraft.com]. Looks like most people are taking about two years to build them. Once you have built the plane, you will know everything about it. Take the LSA Repairman course (16 hours) and you can do all the maintenance yourself. Plus, it can run mogas to save even more money. | | | | | Joined: Jan 2004 Posts: 13,969 Member/10,000+ posts! | | Member/10,000+ posts! Joined: Jan 2004 Posts: 13,969 | It will be something I can work on without the BS and still fly without a medical. Open to suggestions. Vans RV-12 [ vansaircraft.com]. Looks like most people are taking about two years to build them. Once you have built the plane, you will know everything about it. Take the LSA Repairman course (16 hours) and you can do all the maintenance yourself. Plus, it can run mogas to save even more money. The RV-12 looks like a very nice airplane. But, be cautious Dale. The RV-12 is classified as S-LSA. Meaning that you must build it exactly to manufacturers specifications. No deviation without manufacturer approval. It must be maintained specifically to manufacturers instruction. And replacement parts must be manufacturer approved. No substitution nor deviation without the manufacturer's oky doky. If you are satisfied to live within these restrictions, being an RV, it has little choice but to be a great airplane. Bill Grants Pass, Oregon | | | | | Joined: Dec 2003 Posts: 26,119 Likes: 1292 Member/25,000 posts | | Member/25,000 posts Joined: Dec 2003 Posts: 26,119 Likes: 1292 | The RV-12 looks like a very nice airplane. But, be cautious Dale. The RV-12 is classified as S-LSA. Meaning that you must build it exactly to manufacturers specifications. No deviation without manufacturer approval. It must be maintained specifically to manufacturers instruction. You're half correct. It has to be built exactly per manufacturer specs. However, once it has been certified, you can modify it anyway you want. Read the posts in the RV-12 VAF Forum [ vansairforce.com] about all the mods people have made or plan to make to their RV-12s. P.S. S-LSAs (Special LSAs) are aircraft built by the manufacturers. The ones built by amateur builders (based on the S-LSAs) are called E-LSA (Experimental LSAs). | | |
