Page 2 of 6 1 2 3 4 5 6
Originally Posted by jimkonst
My plan is to placard for a while, then see who has the best kit.
Jim,
You mean the best price?
NOBODY is going to develop a kit for this other than Cessna. Cessna is the manufacturer, they did the engineering, issued the Service Bulletin BEFORE it was an AD, made the kit- which in my opinion is now considered factory parts, AND the Cessna kit and SB is in the AD, so you HAVE to use what it calls for otherwise use a AMOC. Since the Cessna kit is under $100, I really don't see a rush to make kits by another party. So, either buy a kit from Cessna, or install the placard and leave it at that. I'm amazed that the FAA allowed owners to slap a sticker on the panel and promise not to do spins. Sticker or not- it'll still spin!!!
-Brian
I am looking at that gap behind that now larger bolt head. If those rudder horns are as flexible as Charles describes. and if they ever jumped into that slot behind the bolt........... That's scary!!!
"Thanks Hung. I am now even less inclined to install the kit."
I kinda agree, I looked at mine, back in 07, and have watched it ever since. My opinion, (I know, the AD matters, my opinion dosn't) if the 150 has been maintained, not had its tail beat against the pavment, or otherwise mistreated, the rudder stop has been on it around 40 years, there is nothing wrong with it.
Think I will be installing placard, for a while.
If any one knows of an actual problem, let me know.
Bob W "We cant control the wind, but we can adjust our sails."
Originally Posted by Brian_Anderson
Why are there 5 or 6 threads exposed on the left stop bolt and none on the right? There doesn't look like there are any threads beyond the lock nut at all, which isn't right.
I think the mechanic had to cut the right stop bolt short, because at full-length he couldn't get it inside the horn to start the thread. Apparently there was enough room on the left side.
Even at shortened length, there's enough of the bolt inside the locknut to keep it secured. Plus, the nutplate that the bolt is threaded through is enough to keep it from going anywhere.
Hung #203353 05/25/09 01:08 AM
Dan Offline
I never use the rudder anyway...just open a door and force it into the airstream, seems to work fine for me. So I'll just placard the airplane.
"Sticker or not -- it'll still spin!"
Brian, don't you believe in magic?
Kinda like the auto gas STC. One minute your plane cannot burn auto fuel. Pay $150, get a piece of magic paper and PRESTO! Your airplane magically transforms int one that can use auto fuel!
Ain't it simply amazing?
Grants Pass, Oregon
I believe in Love at First Sight...
I believe in the Easter Bunny...
I believe that for every drop of rain that falls, a flower grows...
I believe I'm gonna be sick!
sick
( grin )
All Poobs here has to say about all this...
...wellllllllllllllll...
...ya'll don' haveta woory bout Poobs doin' spins. eek
Poobs don' like spins. sick
(actually... it's the "G"'s).
:/Piece of mind; (not that I have much, but I would like to keep what I have intact.) Is the reason I replaced the rudder stop under the SB. I worked with my A&P and got it done in under an hour. Now it is done and out of my thoughts.
If you do this, I recommend that you remove the old rudder stop on the horns first and place the new rudder stop on the horns last. It gives you more room to work on the other parts.
Steve
`83-C152 N94270
Tracker
The AD not carried out in and of itself - no. But the lack of compliance with an AD would make me dig deeper in the books and the aircraft. I would bet that non-compliance with a simple AD such as this one may well lead to other "interesting" things.
I agree.
