#173379 11/24/08 04:11 AM
trying again
Not working, Bernard.
You might ask the Webmaster, Royson, if he can suggest a solution to your pictures posting problem.
try making the size of the photos smaller. Large files do not attach well and are hard to view. Don't ask me how I know!
Tom McMahon #173542 11/25/08 01:19 AM
Tom has a good point there. I used to shoot bigger ones, but am down to 640 x 480 now. This size seems to work best.
Bernard, you apparently did everything correctly, but probably did not click on "Done Adding File" in the file manager after you got the file name to appear above the window. Do not click on the "x" to close the file manager window manually. It's important to WAIT for it to close on it's own (which it will do once "done adding files").
Carl Chitwood #173605 11/25/08 12:53 PM
Here is the problem I had for so long. I had Block Pop-up Windows selected and I could not post. When I allowed them, I could post pics.
Catherine #173613 11/25/08 01:51 PM
Oh Catherine, stop popping up in the window. grin
Geeeeezzze...... crazy crazy crazy
...ducking...
Carl Chitwood #173665 11/25/08 06:11 PM
Carl
I could not get the file name in the window.I followed Hung's instructions to browse then my pictures came up and I selected one but could not get it to the forum post.
Bernie
Bernie,
Try getting into the forum using THIS LINK and see if you can post the pictures.
You did it once at least, Bernie! The file name you selected appears in your post above, but the link isn't complete. That usually happens when you forget to click "Done Adding Files".
Try it again. It worked before! All you have to do is complete the correct sequence.
Click on "File Manager". The file manager screen appears.
Click "Browse" and the browser screen appears. Find your file.
Click on (or double click on, if needed) the file you want to load. The browser screen disappears and the file you selected now appears in the file manager's window.
Click on "Add File". Important: wait for the filename to move to above the window indicating the file was uploaded!
Click on "Done Adding Files" to complete the process, and the file manager disappears so you can complete your posting.
