| Joined: Sep 2008 Posts: 1,341 Member/1000+posts | Member/1000+posts Joined: Sep 2008 Posts: 1,341 | No. No pics as yet. But I will post some when it's done - in about 2-3 weeks. I am still awaiting some parts from Plane Plastics. | | | | Joined: Sep 2008 Posts: 1,341 Member/1000+posts | Member/1000+posts Joined: Sep 2008 Posts: 1,341 | No.No pics yet. I will take some and share them with you, Jim, and the other members when the project is done - hopefully in a couple of weeks. | | | | Joined: Sep 2008 Posts: 1,341 Member/1000+posts | Member/1000+posts Joined: Sep 2008 Posts: 1,341 | Jim - I think I sent you a msg. on the other topic, but if not your decal went out in the mail here Monday a.m. | | | | Joined: Jan 2007 Posts: 3,640 Likes: 49 Member/2500+posts | Member/2500+posts Joined: Jan 2007 Posts: 3,640 Likes: 49 | Excellent Paul! Thanks! I get home Friday afternoon.
Thank you very much!
Delta Pilot Ghetto KFFC Falcon Field N378T
| | | | Joined: Jun 2006 Posts: 7,159 Likes: 211 Member/5000+posts! | Member/5000+posts! Joined: Jun 2006 Posts: 7,159 Likes: 211 | Hi Paul,
If you have any more copies, I would like to try one.
Thanks! Catherine
| | | | Joined: Aug 2007 Posts: 1,976 Member/1500+posts | Member/1500+posts Joined: Aug 2007 Posts: 1,976 | Hello, Paul,
I sent a SASE out to you on Friday. If you still have some stickers, please send me one (or two).
If you are out of stickers, just dispose of the envelope.
Thanks, Phil
Philip Mitchell Attorney, CFI, A&P N150BP C150L | | | | Joined: Sep 2008 Posts: 1,341 Member/1000+posts | Member/1000+posts Joined: Sep 2008 Posts: 1,341 | OK, Phillip. Roger, wilco. | | | | Joined: Jan 2007 Posts: 3,640 Likes: 49 Member/2500+posts | Member/2500+posts Joined: Jan 2007 Posts: 3,640 Likes: 49 | Paul, Here is a shot of the finished product here. Just sanded and painted my gust lock bright red and added your fine sticker. Looks THOUSANDS of times better than my beat up old junker! Thanks again, what a great club!! [ Linked Image]
| | | | Joined: Sep 2008 Posts: 1,341 Member/1000+posts | Member/1000+posts Joined: Sep 2008 Posts: 1,341 | Looks nice, Jim.
I left mine (the original) a little larger. I used one end of a three hole punch to cut out holes so that the two rivet heads would protrude thru them so that I could apply the decal flat to the enrire surface of the metal plate.
Then I applied a coat of clear polyurethane to the whole thing to try to keep it from getting dirty or greasy. | | | | Joined: Jan 2007 Posts: 3,640 Likes: 49 Member/2500+posts | Member/2500+posts Joined: Jan 2007 Posts: 3,640 Likes: 49 | I just trimmed it quickly to fit and burnished it down around the rivet heads. It snugged down fine, its just hard to tel in that pic. I'm thinking the same thing with polyurethane idea or some from of clearcoat.
I probably could have done a better job of matching the sticker to the shape, but i'm very satisfied with it. I may even get some Blue reflective tape for the center Chevron as that's what the original had before I clearcoat it.
