| Joined: Jul 2008 Posts: 93 Member | Member Joined: Jul 2008 Posts: 93 | Experimental C of A
I know of a few people with Cessna like aircraft that were transfered to the experimental category. One easy way to do it is to build wings for it, the FAA and transport Canada considers that 51%. Building wings might sound like a large endeavor but a company in Quebec has a kit built aircraft called the cyclone, the aircraft is a Cessna clone and the wings will fit on a Cessna. That takes care of the 51% rule..... while retaining aircraft flight characteristics.
| | | | Joined: Dec 2003 Posts: 2,134 Member/1500+posts | Member/1500+posts Joined: Dec 2003 Posts: 2,134 | Experimental C of A
That may be what transport Canada considers 51% but it is not what the FAA considers 51%. Perhaps in the past, the FAA was more lenient about what it considered substantial modifications to standard category aircraft and licensing them as amateur built but those days are gone. In fact, the FAA is in the process of redefining how it comes up with 51% and it is causing some nervousness in the kit manufacturing business. Current approved kits are grandfathered but new kits close to being marketed may find that the FAA will not approve them if too much of the aircraft comes pre-built.
Tim '76 C-150M, San Antonio
| | | | Joined: Aug 2007 Posts: 1,976 Member/1500+posts | Member/1500+posts Joined: Aug 2007 Posts: 1,976 | Good parts plane? Wonder what the engine would bring?
Philip Mitchell Attorney, CFI, A&P N150BP C150L | | | | Joined: Jan 2004 Posts: 13,969 Member/10,000+ posts! | Member/10,000+ posts! Joined: Jan 2004 Posts: 13,969 | Good parts plane? Wonder what the engine would bring? The O-320 H2AD engine? Not much!! Bill Grants Pass, Oregon | | | | Joined: Dec 2003 Posts: 14,789 Likes: 546 Member/10,000+ posts! | Member/10,000+ posts! Joined: Dec 2003 Posts: 14,789 Likes: 546 | Good parts plane? Wonder what the engine would bring? The O-320 H2AD engine? Not much!! Yup - that engine came with a built-in Airworthiness Directive right out of the factory doors. It taught Lycoming never again to put the letters "AD" into the model number.
| | | | Joined: Dec 2003 Posts: 2,134 Member/1500+posts | Member/1500+posts Joined: Dec 2003 Posts: 2,134 | I've heard that once the bugs were worked out, the -H2AD engine is reliable. I'm sure it was painful to those owners who had to live through the process though. I would not rule out an aircraft with this engine today without doing some careful research and ensuring it was properly modified.
| | | | Joined: Dec 2003 Posts: 14,789 Likes: 546 Member/10,000+ posts! | Member/10,000+ posts! Joined: Dec 2003 Posts: 14,789 Likes: 546 | I've heard that once the bugs were worked out, the -H2AD engine is reliable. Good point. I just helped work on a 172 with the -H2AD engine. It's flown pretty regularly with no issues. The most obvious continuous maintenance is the need for an anti-scuff additive in the engine oil. And I believe AeroShell 15W-50 comes with that additive 'built in'.
| | | | Joined: Nov 2004 Posts: 5,465 Likes: 22 Member/5000+posts! | Member/5000+posts! Joined: Nov 2004 Posts: 5,465 Likes: 22 | I personally am not very excited about having one drive to drive what is supposed to be two mags - one failure in the wrong place, (and not necessarily in the engine its self) and their both gone
Matt Gray
aerobat@cessna150pilot.com
A150K@hotmail.com
| | | | Joined: Dec 2004 Posts: 10,735 Likes: 108 $ Member/10,000+ posts! | $ Member/10,000+ posts! Joined: Dec 2004 Posts: 10,735 Likes: 108 | This one doesn't have mags, it has an electronic ignition. Neato!
Jeff Hersom N3740J '67 150G "Gremlin" Hangar W-6, Helena Regional Airport Places I have landed Gremlin: ![[Linked Image from visitedstatesmap.com]](https://visitedstatesmap.com/image/ALAKFLGAIDILINIAKSKYLAMIMNMSMOMTNENCNDOHOKSDTNTXWIWYsm.jpg) | | | | Joined: Jan 2004 Posts: 13,969 Member/10,000+ posts! | Member/10,000+ posts! Joined: Jan 2004 Posts: 13,969 | The bidding is going higher then I really thought that it would! I would love to hear what those that are bidding thoughts are??
