Page 5 of 6 1 2 3 4 5 6
I must agree with almost everything Harvey mentioned.
Maintainers are supposed to be only interested in maintenance and repair activities. As Harvey correctly mentioned, the maintainer is only required by regulation to make a list of any discrepencies he/she finds during the course of an annual inspection.
FAR 43 details what is to be looked at during the course of an annual inspection. No where does it state for a maintainer to check AD's, C of R's, C of A's, etc. These activites are part of the owner's / operator's responsibilies. Prior to each flight, the owner / operator is to ensure that the aircraft is both safe for flight(physically safe) and legally equipped to fly (legally safe).
The acronym "ARROW" comes to mind.
Here's an example. A 150 has an annual inpsection completed. It is discovered that the aircraft's position lights are unservicable. Is the aircraft grounded until repairs are made? No. The maintainer makes a note of it in the aircraft logbook, there-by notifying the owner of the discrepency, placards them and then signs off the maintenance performed. The aircraft is safe for flight without position lights and is legal for flight during the day only. If the owner then decides to fly at night, it's his responsibility.
That's my logic, anyway.
John
John
150-61401
C-FUUE
Thank you. I was able to read that the reg's require a review of repairs, modifications, etc. which require looking at the log books to verify the completed work. I was afraid for our fellow aviator that there is no regulatory requirement - Good practice, Yes - but no requirement that the AC or Registration be reviewed by the signing A&P-IA. As you suggest, it is the owner/pilot responsibility to insure the papaerwork is complete. Take care.
Mike Dann
1975 A150M Tailwheel Aerobat
Gardner (K34), Kansas
(Sorry folks but this one came out a little long winded but it contains a lot of good information about annual inspections… and also dispels a few old wives tales.)
True, FAR 43, App D, does not specifically state that compliance with ADs must be checked during the annual inspection but this is how it works...
The annual inspection is not necessarily an inspection to make sure something isn't about to fall off your airplane (although that is what the annual is usually seen as.) The real purpose of an annual inspection is to make sure the aircraft still conforms to the Type Certificate under which the aircraft was originally approved for flight by the FAA. And if the aircraft conforms to the TC, its Airworthiness Certificate is valid. Of course, if the aircraft still conforms to the TC, then it is considered to be as safe as the day it was approved by the Feds. Therefore, the TYPE CERTIFICATE is the ruling authority of an annual, not FAR 43, App D. (FAR 43, App D is only a minimum guideline of what should be looked at during an inspection. Conformance with the TC is still the prime directive.)
Okay, I see lots of raised eyebrows out there but please bear with me…
In order to conform to the TC, this means that every part of the aircraft must be in an as-originally-built condition, i.e. any repairs to a part must return that part to its original specifications/drawings, no worse but no better either. (If the repaired part is "better" than the original part, then that repair is also an alteration because “better” doesn’t conform to the original specifications for the repaired part.) It also means that the aircraft contains no modifications not already allowed by the TC. (The TC allows some pre-approved mods such as the addition or deletion of wheel pants.)
However, the TC also lists the minimum required items in order for the TC to be valid. Can you placard your nav lights as being inoperative and still fly during the day? Not if your aircraft was originally certified under the TC for both day and night VFR/IFR (in which operable nav lights are not optional.) In order for you to LEGALLY fly during the day with inoperative nav lights, your IA must submit a 337 to the feds requesting a field approval for a modification to your TC to remove, even if just temporarily, the nighttime operating allowance of the TC. The alternative is for your A&P to submit for a ferry permit to allow you to fly somewhere to get your nav lights fixed. It’s because the TC says that your nav lights are REQUIRED items and not optional like wheel pants or a malfunctioning Hobbs meter. (Don’t kill the messenger folks. I’m just telling you what the regs and feds say.)
Conforming to the TC also means that any amendments to the original TC (and Airworthiness Directives ARE amendments to the TC) must also be complied with. Therefore, when your IA checks to make sure your airplane conforms to the TC, he/she must ALSO make sure it conforms to any amendments. This is why doing an AD search is part of your annual inspection, even though FAR 43, App D says nothing about it.
Your IA also has to make sure that any previous modifications to your airplane are approved (via STC or Field Approval) and that any previous repairs are in compliance with approved methods (manufacturer's repair manual or FAR 43.13-1b.) Any repairs not conforming to applicable standards, or any unapproved modifications, must either be removed or made right by the IA before he/she can return your Cessna to service because when that IA signs off your annual, he is also certifying the integrity and legality of all the maintenance and modifications made by others before him! (Remember – Your IA ends your annual with the statement that your little Cessna is in an airworthy condition. There is not an exclusionary statement that says “except for any work performed before me by others.” He knows that his signature in your aircraft’s log is hanging his butt out for any lawyer to chew on. This is why most IAs eventually develop nervous facial twitches!) And this is why your IA will look through your aircraft’s logs as part of an annual, even though FAR 43, App D doesn’t say to do so, because he/she is trying to get a heads up on those previously repaired parts of your Cessna that will require extra scrutiny during the inspection.
So, in a nutshell, the FARs require that your aircraft has a valid Airworthiness Certificate and for that AC to remain valid, the FARs require that the aircraft be maintained and operated in accordance with the original Type Certificate and any amendments. And FAR 43, App D doesn’t make this little connection. Most IAs will tell you that it isn’t any special inspection skills that we learn in IA school; it’s how to interpret the confusing FARs!!!
And by the way, the aircraft’s flight manual/pilot’s operating handbook is spelled out in the TCs of most of our Cessnas as being a required item for flight. This means that flying without it is a failure to meet the requirements of the TC. And if the TC isn’t followed, then the Airworthiness Certificate displayed in that little plastic case by your left knee is invalid. And then the man in the suit with the clipboard standing by the gas pump when you taxi up can remove your favorite body parts with a few strokes of his pen!
To answer Chris’s original question, he can get his Airworthiness Certificate reinstated but only after he proves to the FAA (via a DAR inspection) that his airplane complies with the original TC. And that may not be easy, or cheap! He may need to contact an aviation attorney in order to go after the last owner for reimbursement of his DAR expenses. (Again, assuming that the last owner sold the plane to Chris with the implication that it was airworthy and legal to fly.)
Harvey
Retired USAF Meteorologist
1976 Cessna 150M
1942 Stearman
1942 Harley 45" Flathead
1932 Airway Beacon
2015 22" Sears lawnmower
Several houseplants
Half a bag of Twizzlers...
Thank you for the most lucid explanation of this topic I have ever seen. Perhaps we ought to have you do a session at Clinton next year. What do you think, gang?
Mike Dann
Mike,
The crowd is uncharacteristically quiet. I suspect they're all huddled over their FARs with magnifying glasses looking to see if the outlandish statements that I made are true.
I can save you the trouble guys. It's all spot-on. I ran it past my PMI before submitting it last night and he, too, thought it was a good explanation of an often-misunderstood topic.
(My "PMI", or Primary Maintenance Inspector, is the FAA maintenance inspector at the Houston FSDO that I answer to. Each FSDO has several inspectors designated as PMIs and all of the IAs reporting to that FSDO are assigned to PMIs. Depending on the size of the aviation community, each PMI might have 5-20 IAs "reporting" to him. In a nutshell, the PMI is the liaison between the aviation maintenance community and the Big Bad FAA.)
Harvey
1976 Cessna 150M
1942 Stearman
1932 Airway Beacon
Several houseplants
This is always an interesting topic. Several years we met with an AME/A&P who told us what he can do and what we are responsible for. Technically, we are the "Director of Maintenance" for our own aircraft. As the Director of Maintenance it is up to us to see that all AD's SB's etc are complied with and that when things break we get them fixed. If you feel you are being hosed by an AME/A&P you as the Director of Maintenance can take him/her to take a hike and get another opinion. The AME/A&P is the person who performs the the work and signs off on the work he/she has done.
Harry Wiebe
C-GPSU
Winnipeg
That pretty much agrees with what the local AME (Len McKay) told the Greenbank Wheel-In folks last weekend.
He describes, we decide!
Reg Scotland
CF-YIL
1960 C-150
Near Toronto, Ontario Canada
I'm just saving the trouble of arguing...you seem so confident...and I don't agree with everything you said. Particularly regarding the need to do a 337 to fly the plane during the day if the nav lights don't work. I respect what you're trying to do, so I'll leave it alone.
Without an MEL, the FAR's provide guidance regarding operation of an aircraft with inoperative equipment. The FAR's also specify inspection requirements of that inoperative equipment. There is no need to do a 337 to document deviation from the type design just because of inoperative equipment.
I wouldn't have argued until you spat off that bit about being spot on, which I believe you're not in this case.
I did enjoy your dialogue of what an annual inspection is.
I've enjoyed reading your posts, Harvey. My curiosity is now peaked. If somebody was to bring a modified aircraft to you...................well, let's be more specific. Let's say Gary brought his 150 in to you for an annual inspection. It has been modified with an O-320, taildragger, as well as other changes. Which means quite a few STC and field approved modifications. Many of which are only described by blueprints. What would be your basic charge to do the Annual Inspection on this aircraft? How much time would you allow to do an Annual Inspection on such an aircraft?
WOW! It's funny how this thread has changed course! crazy
I'd like to make a suggestion. It might be a good idea to create another section within this forum to cover these very in-depth and complicated regulation related questions and ideas. I don't think this discussion should be held in the buyers & sellers area and under the title "Sale problems". Just a thought.
Though we would all like a "magic" answer to a regulatory type question (ie: yes or no), there are times when there is no magic answer and all you can do is discuss it with your local FAA or TC "expert" and go off of what he tells you. The one thing that I have learned, though, is the answer you get from an "expert" is
still only an interpretation of the rules. In the end, it is up to the person doing the asking if he/she is going to follow the advice that is given.
In the example that I mentioned, with the position lights being U/S, if the person certifying the annual feels it's necessary to have this field approved for the aircraft to legally fly, go for it. I, myself, have another opinion on the matter. Who's interpretation is correct?
We may never know! confused
John
150-61401
C-FUUE
