Page 9 of 10 1 2 7 8 9 10
Originally Posted by Joshua_Ralph
Going to pull the cowl off this week
Enjoy yourself and tell us about the new words you learn as you do this. grin
Good luck!
Bill Simons
Philippines
Removing it isn't an issue -
...it's puttin' it back on...
...solo. whistle eek
^^^^ Agreed!!
K Offline
I think it has a leaky fuel tank...
The owner said it will burn about 8 gallons an hour in cruise...
Probably 5-6 gallons go into the engine and 2 gallons streaming behind the plane grin.
You just might be right.
A couple of years ago a 182 came into the pattern here, streaming enough fuel that we could see it from the ground.
The GAS CAP was loose!
Likewise, a bad or hard gasket can let gas out -- there's a strong vacuum over the fuel filler. This is why it's a good idea to replace the gaskets periodically, even if they feel ok.
K Offline
3. I needed something to save time on my 500mile commute back and forth from work each week. Yes, I'm prepared to drive when the weather is not VFR compatible.
First, I think you made a great decision, and I'm glad you got such a good plane. The 150 has no bad habits, and it's hard to get snakebit buying one with a current annual. The 150 is a plane that you can fly for fun, without having to justify ownership. I equate it to an early Ford Mustang -- 2 seats plus some room in back, simple, lightweight and sporty without being high-maintenance.
Second, I suggest a mind-set adjustment. PLAN to drive, be PREPARED to fly IF conditions are suitable.
Third, now that you have it, RESIST THE URGE TO JOIN THE MOD SQUAD for at least the first 100 hours of flying. There are a bunch of things that you can do to your plane, but you should get comfortable with it before you start making changes. You may not need something that looks like a must-have right now.
Fourth, GO FLY SOMEWHERE. We joke about the $100 hamburger (with a 150, that's about a $50 burger), but seriously, you will soon get bored with flying around the local area without having somewhere to go. Get a paper Sectional and mark the places you want to go, then the dates that you get there. Get a notebook, and write down comments about the places you fly.
As I said above, you've made a great decision, and it will pay off in the years to come.
Yes Yes Yes!
100% true!
Originally Posted by Ed_Pataky
Yes Yes Yes!
100% true!
So when are you going to "GO FLY SOMEWHERE"? Adventure awaits!
1967 Cessna 150G
Lifetime Member
2016 & 2019 Top Gun Pilot
Yes Yes Yes!
100% true!
When I get some money.
Yes Yes Yes!
100% true!
I Gotcha a Dollar!!! [m.youtube.com]
1967 Cessna 150G
Lifetime Member
